Machine alignment test file
Posted: Tue Jun 16, 2015 5:01 pm
Basic mechanic movement testing. If the machine has mechanic issue, you will see double line when laser head return from each path
Re: Machine alignment test file
Posted: Mon Oct 05, 2015 1:10 pm
Sorry for what I posted a wrong file from above. It should be these two files of the following attachment
Of the file, the laser head will try to cut a line from both end. If the pulley or belt got lose, the lines will not intercept each other from the return path
