Machine alignment test file
Basic mechanic movement testing. If the machine has mechanic issue, you will see double line when laser head return from each path
Re: Machine alignment test file
Sorry for what I posted a wrong file from above. It should be these two files of the following attachment
Of the file, the laser head will try to cut a line from both end. If the pulley or belt got lose, the lines will not intercept each other from the return path
Wheel_Single_Line.ai
(88.29 KiB) Downloaded 701 times
Multiple_Single_Line(A15).ai
(23 KiB) Downloaded 654 times
Single_Line(A20-25).ai
(11.63 KiB) Downloaded 655 times
Return to “Laser & CNC products”
