Has anyone got a wiring diagram for these switches please.
Cheers
Pete
Capactive Proximity Sensor Switch
Pete
Re: Capactive Proximity Sensor Switch
Don't know the type you have but if it has 3 wires: Brown, Black and Blue, then connect it as follows:
Brown +V (normaly from 5 - 30V but check the datasheet)
Blue GND
Black Output, depending on your type it will switch to GND when triggered or open or even switch to +V....
Blue GND
Pete
Thanks for the info, going upgrade the switches when I replace the controller so trying to work out everything.
Cheers
Pete
Cheers
Pete
Users browsing this forum: No registered users and 17 guests
