K40 for engraving - Need to upgrade to DSP?
Posted: Wed May 20, 2015 2:05 am
I bought a new K40 a couple of months before in order to engrave steel tags.
Being completely new in that business, it took me several days to set up it correctly (align otical path, understand Moshi SW a bit) and manage to engrave a few tags.
My problem is that the engraving quality is very low and in many cases the letters are not complete (as you can see in the photo, parts of the letters are missing and sometmes the words are not in the same line). I did several tests with different speeds and positions and I didn't managed to fix the problem. To my understanding the problem comes from the SW and not the machine.
The settings I use are:
-Cermark as a Laser Marking Ink
-Current Indication 20mA
-Engraving Power 100%
-Engraving Speed 1 cm/s
So, my question is, if the upgrade to DSP will help me to not have such issues.
I am ready to place the order of the AWC608 DSP upgrade kit for D/K40 small CO2 laser machine as soon as I get an indication that I will be able to engrave my steel tags.
Thanks a lot
PS: I have attached the photo of my Power Supply, in order someone to see if I need to change it as well when I do the DSP uprade
Thanks a lot
