Door Switch / Open Protect Behavior Change?
Chankster
Post by Chankster »
On the AWC608 did the behavior for the door switch (Open Protect) change from previous firmwares? I was previously running a firmware from 12.09.21 and the door functioned fine. After upgrading to two different firmwares from 2013 and 2014 the behavior suddenly changes. I would downgrade back to 12.09.21 but the link from Marco's email is dead.
Currently, the machine will only run if the door is open when it starts. Closing the lid will cause it to pause but it will not unpause when the lid is lifted.
Anyone have any ideas or can send me the old firmware for testing (OS120921.rar)?
Chankster
Re: Door Switch / Open Protect Behavior Change?
Post by Chankster »
anyone?
Post by baccus61 »
I have 131210 V678
versions 6,7,8.
Is that any help?
Chankster
Post by Chankster »
I tried 130621 and got the same result.
What kind of doorswitch you use? maybe it's easier to change the wiring from NO to NC or visaversa..for future sake..
