Stepping motor controller board & tester p/n ECNC-SC04
sogambler
Post by sogambler »
I'm trying to teach myself how to use stepping motors so i ordered these two items from Lightobject
Mini 2 Phase 1.5A 1-axis Stepping Motor Driver p/n ECNC-2M415
Stepping motor controller board & tester p/n ECNC-SC04.
I salvaged a couple of stepping motors from old printers and scanners that i can use for testing.
Neither of these parts came with any documentation. The controller board tester does not have any documentation on how to set the switches or adjust the speed.
Does anyone have any wiring diagrams on how to connect up these?
Many thanks Dan
Laser Engraving and Cutting FB group
https://www.facebook.com/groups/441613082637047/
Re: Stepping motor controller board & tester p/n ECNC-SC04
viewforum.php?f=16
Check it out here
bonnette_l@yahoo.com
Post by bonnette_l@yahoo.com »
I used these components to drive my "Z" table.
you can find a diagram I used here:
download/file.php?id=2231
Larry
Kiwi53
Post by Kiwi53 »
Hi
Larry got your diagram for the Z table, good work,
like to know how the limit switches are wired into the
stepper controller (ecnc-so4 controller).
Do you know if not can Marco shed some light on this matter.
Neil
Hello Neil
I didn't wire in any limit switches for the z table.
But you could add them so that they are in series with each of the up and down buttons.
So, when you are pushing the up button, when the table reaches the upper limit switch the up button gets disconnected.
But the down button still works. And so on...
Larry
