Question about CorelDraw Macros
reeser
Post by reeser »
Hi All:
I need some help. When I try to get the LaserCad macros into CorelDraw I have a problem.
I have CorelDraw X5 and when I run the CorelDraw Plug in in LaserCad the Macros show up in CorelDraw as expected. However the Macro AWCLaserCut.ImportDstFile macro doesn't work. I get a runtime error 91 with the message "Object Variable or With Block Variable not set". The Macro AWCLaserCut.AWCLaser Start works like expected.
Has anyone encountered this problem or have any advice as to how to correct it?
Dick
Re: Question about CorelDraw Macros
Sorry I have no idea what is the problem you have. I have no access the password as I am not the programmer or the one who wrote the code for the macro. I can only support to certain level and to an extend that my knowledge is good to be.
BTW, I didn't recall anyone has problem to run macro on X5 in general. May be they didn't use the IMPORTDST and I never used that feature at all. I don't know what is "DST" file at all. Can you explain what is your goal?
What windows OS do you have? What DSP you have? Let me know and I'll forward your question to Li who is the programmer
reeser
Post by reeser »
Thank you for the quick reply.
I am running Windows7 and CorelDrawX5.
My DSP is LO-X7
I have no idea what the IMPORTDST is either but I thought it must be required somehow because it is covered in the instruction document that Tim Wehr produced.
If the only Macro that is important is the LaserStart Macro then I don't have a problem. That macro works fine. It is the Init and ImportDST macros that are the problem.
If they aren't used for anything I've been messing around for 10 days on a non issue.
Could you let me know?
I appreciate the help.
Dick
I think that macro is for some special file format that you and me hardly used. So far, I heard nothing about DST. The only file I saw was "DBT". Just ignored it. I'm pretty sure you won't need it. As long as the Start macro works, you're on the right track
