How many amps does the power supply draw?
StevoLaser
Post by StevoLaser »
Hi,
I am about to purchase a relay to control the off/on power to the laser power supply. I've got the JLD40W.
If the draw of the power supply truly is 20 to 45watts and I've got a 35watt tube then:
watts/volts = amps
35 watts / 120 = .291 Amps
Does that sound right?
Steve
Re: How many amps does the power supply draw?
No. Get 4A or 5A instead
The CO2 laser tube is not 100% efficiency but 10% only
StevoLaser
Thank you Marco
