Hy guys,
Here is the latest diagram to re-wire the chinese laser with the Lightobject DSP...hope it helps someone...
Any questions or modifications please let me know...
Ciber
New wiring diagram...finally!
ciberbob
- Laser - Diagram - 02-18-2015.pdf
- (965.52 KiB) Downloaded 1045 times
Kiwi53
Re: New wiring diagram...finally!
Nice one Ciber, pity it couldn't be put as a sticky note.
Would save a lot of searching for the wiring diagram.
AndyKunz
Would it be possible to get the labels larger?
In particular I have to zoom to 150% to read the white-on-black limit switch inputs, Water SEnsor, etc.
It looks nice, though. Thank you for making it.
Andy
Andy
Also, add "Opt/+5V" because only M415 is marked "Opt" while other drivers are using +5V
Thx
Thx
mikenmel08
That would have been tremendously helpful when i was wiring mine......GREAT WORK
ciberbob
Hello,
Thank you for the inputs...
Here it is with the modifications...
Ciber
PS: It's a pdf file, and you can zoom in as much as you want...
Ciber
- Laser - Diagram - 03-04-2015.pdf
- (110.77 KiB) Downloaded 949 times
Prefect!
May I offer you $20 coupon for your great job!
andres.arena
mini rotatory
Help me
I have problem
mini rotatory
not installing.
in which Z-axis or U?
probe in both
but does not rotate.
what should I do?
thank a diagram please
I have problem
mini rotatory
not installing.
probe in both
what should I do?
