Hello,
I recently purchased the Solar water pump 40L/m (635GPH) DC24V High Temperature (100 'C) off of Amazon. The product description on Amazon indicates that this pump may be used with both 12V and 24V. I would like to connect this pump to a solar panel which is 12V. However, the pump we were sent is 24V. I am working with Mercy Ships in Madagascar and do not have access to other pumps. Is there a way to make this work?
cdummann
Re: Solar water pump 40L/m (635GPH) DC24V High Temperature (
The pump work for 12V but flow rate drop
Solar panel (12V) output is more than 12V but possible up to 19~21V.
Make sure the panel can output enough current to drive the pump
