Beyond size continue
the_dude
Post by the_dude »
Hey Everyone,
I am trying to cut my first files out a small test of 75mm( work area of 600x900 for the machine) and the dsp keeps saying beyond size continue?
I have searched here pretty well, read the manual as well as checked my manufacturer parameters and user parameters to make sure everything is set right for the motors.
If I hit test on the dsp, or run box or clip box in laser cad I still get a message saying beyond size.
What am I missing?
Cheers and thanks for the help :)
brian257
Re: Beyond size continue
Post by brian257 »
What speed are you trying to cut at?
the_dude
Post by the_dude »
100?
AndyKunz
Post by AndyKunz »
Did you set the size in the Manufacturer Settings tab yet? And then you need to download to the controller.
Before you do anything, tell it to READ first.
Andy
the_dude
Post by the_dude »
I changed my speed and power to 10 each and shrank my bow down to 10 mm , still beyond size?
As i said even hitting test on the DSP gives a "beyond size !" warning.
what could it be that fundamentally is making everything beyond scale?
Should I screen shots of my parameters?
Cheers
AndyKunz
Post by AndyKunz »
Yes, that would help immensely.
Andy
the_dude
Post by the_dude »
Let me know if there are any other screens you would like me to capture! and thanks in advance for the help!!!
I am so close to getting this to go
Image--
Machine zero, Page zero and Position relatives must match your home location
If it is Top Left (Up left), set all those to Top Left
Your setting didn't match at all
the_dude
Post by the_dude »
Thank you Marco!!!!
the_dude
Post by the_dude »
So my next question is about getting the laser to fire.
When I press the laser button on the DSP controller the laser does not fire.
When I run a program the laser does not fire.
But when I press the red test button on the power supply box it fires. I checked my wires and everything looks okay.
I also checked to make sure my water protect circuit is unchecked in my options so that isn't stopping it.
Thought? things additionally I should check? Screen shots that would help diagnose the issue?
Cheers
I am thinking that you didn't ground the "WP" - the water protection.
That's why it won't fire
the_dude
Post by the_dude »
Will Check tonight and let you know.
the_dude
Post by the_dude »
Worked great thank you Marco!
the_dude
Post by the_dude »
Next question, after say 10 hours of being on as i have been trouble shooting this project my red light laser has died, voltage is going to it, I checked the power supply and wire connections.
Is that normal? do they have a life expectancy?
the_dude
Post by the_dude »
adfs
