Can't find Autocad
MrWoodyCrafts
Can't find Autocad
Post by MrWoodyCrafts »
Looking for input, I have read everything on the form about the same problem with Corel Draw.
Info:
OS Windows 7 Pro, 64 bit
Autocad 2013 64 bit installed in c: program files X86
Installed Laser cad in program file X86, no problem work fine.
When I installing plugin for Autocad I get error " can't find Autocad " I have tried to install
it in different locations within Autocad with no luck.
I have 3 CNC routers running from Autocad and was hoping to run my laser from there
to so I don't need to learn one more cad program.
All input is welcome.
Woody
AndyKunz
Re: Can't find Autocad
Post by AndyKunz »
MrWoodyCrafts wrote:I have 3 CNC routers running from Autocad and was hoping to run my laser from there
I export as DXF, then import into LaserCAD for creating the cut file and moving it to the laser. Took me maybe 15 minutes to learn.
Andy
