I am able to communicate with the DSP via USB just fine but would like to get the network connection set up. I have the DSP hardwired to a hub that is hardwired to my wireless router. My computer is wireless to the router. The routers DHCP usually assigns 198.168.1.XXX addresses. I figured that it would assign the DSP an address but that is not the case. I assigned the network address in LaserCAD to 192.168.1.125. Then I went into the DSP setup via the menu button to set the network address and I am unable to change it. I arrow to the part of the address and select Enter to change it and the display goes back to the prior menu on the display. I am probably not using the correct procedure to change the network address in the display. How can I change it and if I do, am I going about this the correct way so that the LaserCAD v7.36 program can communicate with the X7 DSP?
thanks,
Bill
Setting network address in X7 DSP
whmeade10
Users browsing this forum: No registered users and 61 guests
