AWC-608 Setup Questions
Posted: Sat Dec 06, 2014 7:25 pm
Hi All -
I just finished upgrading my LaserSaur to use an AWC-608 controller - it's working pretty well straight out of the box, but I need to do some tuning
of the motor parameters and wanted to get some advice/tips.
It raster etches/engraves just fine, but when cutting, there's some jitter at the end of travel, and I'm not sure if I need to twiddle with one of the
different acceleration parameters or one of the Jerk settings. The attached picture shows the problem.
First up - the machine... It's an early model LaserSaur (open source) laser cutter - their software just wasn't up to snuff and I've upgraded. It's
got belt driven stepper motors and a standard 100W glass CO2 tube.
The different parameters from LaserCAD are as follows:
MFG Parameters:
um/pulse = 2.388541
Pulse edge = Falling
Datum = Positive
Key Direction = Positive
Limit Polarity = Positive
Range = 1220mm x 610mm
Start Speed = 15
Max Accel = 1000
Max Speed = 500
Laser Params:
Laser Mode - Glass Tube
TTL - Low Effective
PWM = 20K
Max Power = 98%
User Parameters:
Space Speed = 300
Start Speed = 1.00
Speed Factor = 2.00
Space Jerk = 40k
Cut Jerk = 25k
Min Acceleration = 300
Cut Acceleration = 1000
Space Acceleration = 1000
Engrave Acceleration = 1000
I kinda remember from setting up MakerBot that the Jerk factor can influence that behavior, but acceleration might play in as well.
Any advice on which knobs to start with would be appreciated.
Cheers
Jamie
MFG Parameters:
um/pulse = 2.388541
Datum = Positive
Start Speed = 15
Max Accel = 1000
Max Speed = 500
Laser Params:
TTL - Low Effective
PWM = 20K
Max Power = 98%
User Parameters:
Space Speed = 300
Start Speed = 1.00
Speed Factor = 2.00
Space Jerk = 40k
Cut Jerk = 25k
Cheers
Jamie
