Downloaded the latest OS for the ACW608 and tried to upgrade from the USB drive and got "Upgrade Error!" message. I haven't seen anyone else reporting a problem so I must have a problem here. Any suggestions?
My current system is:
Main Board: 7.14.02.20
LCD Board: 5.12.02.29
Zeke
Upgrade error
Re: Upgrade error
Did yoy format the USB with FAT32?
The DSP card is a little pcky on some memory stick
Sometime you need do more time. Also, you may need to reset the laser machine with the stick plug in to get get syn
Re: Upgrade error
Every time I've failed it's been because I'd forgotten to format the USB stick to FAT32.
Re: Upgrade error
Thanks for the reminder. That was the problem!
