Using Probotix for laser cutter, how could you do it?
sboerup
I'm trying to figure out how we can potentially convert our Probotix Fireball CNC (its the 24x48" version) in to a laser cutter. All we need to do is cut acrylic, thats it. If there is a simple way to make our CNC machine into a laser cutter, how would you do it?
Re: Using Probotix for laser cutter, how could you do it?
There are two ways to do it:
1) Fixed Tube. Mount the tube on a table (not moving). Used two 3x mirror to reflect light beam to a laser head. Just like a regular laser machine
2a) Tube mounted on gantry (vertical). No reflection mirror need. Tube installed vertically and focus by a lens (easlier but need strong enforement. Also, slow speed. Possible 15mm/s at most to avoid collapse)
2b) Tube mounted on gantry (horizontal). Need Need 3 mirrors and a laser head. (more complicated but can operate faster than example 2a)
