Increased range of 4 channel 1527 receiver?
mike 1948
Post by mike 1948 »
Can the range of this receiver be increased by uncoiling the antennae?
My unit keeps cutting in and out when I get beyond 30-50 feet. I have replaced the small battery in the control fob, but it still cuts out unless I stand relatively close to the receiver .
Mike
Re: Increased range of 4 channel 1527 receiver?
The RF unit should be able to communicate in 100ft. If you get 40~50ft, it means that the frequency may be out of 'syn'. Make sure you have both the Tx/Rx 6ft above ground level to get better signal. Also, there is nothing blowing the 'sign of view'. If you used it outside, you may be able to control device in 100~150ft
mike 1948
Post by mike 1948 »
Will help to uncoil the antennae or not?
Mike
