How to Connect Power Supply?
laserkid
Post by laserkid »
Hi I am trying to connect the PWM power supply to the DC 24V PSU that comes with the DSP package from your company. I've managed to connect everything else, and just not sure how to connect this. I'm not very experienced with electronics, so I'm trying to learn as I go along.
Can you please give some advice on how to connect? I'm looking at the circuit diagram provided by Marco. I created a diagram based on what I currently have in my k40, and what I think might be the way I should connect, but I don't think either one is actually right. Everything was pretty straight froward following Marco's circuit diagram until I got to the part where I need to connect the PWM supply / mains power etc.
Can you please provide some advice? I really just want to get the laser to work so I can do some engraving, but I'm afraid I might destroy something if I connect it in the wrong way! Thank you.
Re: How to Connect Power Supply?
It seems fine to me
laserkid
Post by laserkid »
Thanks very much, I will connect like this then!
