60w power supply question
JAV-1
Post by JAV-1 »
On my machine, in hopes of upgrading to a 60 w tube in the future. I am running a 60w power supply and a 40w tube. Currently, the power setting in the LaserCad software is at 45% in the Manufacturer Settings, 75% at the individual settings for the file. With that in mind, while cutting, I'm only getting to 15mA at the meter. I'm looking for help on the settings to get maximum performance and hours from my tube.
Also, when the time comes, where is a good power starting point for the 60w tube?
majuz_mcr
Re: 60w power supply question
Post by majuz_mcr »
Hi. You should ask tube manufacturer how much current it needs, but most of 60w co2 laser runs on 22mA. See below, this is current ratings for standars co2 laser tube, not RECI !
Specifications
Power 40W 50W 60W 80W 100W
Wavelength 10600nm 10600nm 10600nm 10600nm 10600nm
Beam diameter 1.95 2.2 2.5 3.5 3.8
Power output(W) 40 50 60 80 100
Triggering voltage(KV) 22 22 24 28 35
Operating voltage(KV) 15 16 16 18 20
Operating current(mA) 18 20 22 25 30
Outer diameter(mm) 55 55 60 60 80
Length(mm) 700 1000 1200 1600 1800
Power stability ±5% ±5% ±5% ±5% ±5%
Hope it helps.
