Hey Marco...
I'm finding that everytime my laser pulses (like switches from one object to the next) the display resets and I lose my timer. It's really frustrating. I've tried resetting the firmware to older back to 922 but it doesn't make a difference. I checked my wire connections and nothing there either.
Is there a new firmware version that I could use that might fix this?
Laser display flaky
Re: Laser display flaky
It is not hardware issue but the grouning issue. Been emphasized this issue many times by me and by other folks. Use "Search" on this forum and you will see a lot of post mentioning this issue
Ah, ok. Didn't know, I'll go hunting.
Thanks Marco.
Thanks Marco.
If you can't find it, let me know and I will search it for you and explain again. But I want you to learn more as it involved quite a bit info once you dig it in.
I been very busy recently doing new products development and preparing accounting things
I did find it right away...I didn't use the right search terms last time
Using "grounding" is so much faster this time
I can't wait to upgrade to an aluminum chassis so I can just ground to the chassis instead of having separate ground wires
Though I'm debating whether or not to buy a complete machine from you down the road or build one. Do the complete models come with exhaust fans too?
Ugh, I don't envy you dealing with accounting issues...
Ha! How did I totally overlook this? Oh my goodness...what a simple fix.
Thanks Marco! You're the best.
