Raster skewed when placed on top of an imported DXF
SWMS
Post by SWMS »
Hi, I am new to using the DSP and LaserCAD. I'm having a curious issue.
If I import a jpg into LaserCAD and raster engrave it works.
If I create a new file, draw a vector box and import a jpg and cut and raster there is no problem.
If I import a DXF from illustrator, then import a raster image, when engraving the raster image looks like it is skewed.
I've looked at the wiring as this can cause the problem, but this seems to be for when you have this issue all the time. Wiring looks fine.
It appears to be a software issue but if I can't fix that software issue then is there a work around that anyone can think of?
Please help!
