K40 Original mirror damage laser on TH
ivantandy
Post by ivantandy »
My mirror got burned right through the other day- the surface was already in poor shape as a result of PSU malfunction.
Re: K40 Original mirror damage laser on TH
Did you have air-assisted installed? It seems that the surface got smoked on a lot. When the surface is dirty, heat accumulated and due to the diffential of temperature (plus too much pressure on the lens holder), it could crack your lens
ivantandy
Post by ivantandy »
No I have not changed to air assist nozzle yet. I think this cracked mirror occurred when I selected High in LaserCAD at 98 power... when i hit Laser button it fired high but also did not switch beam off. The simple box does not activate laser in TL and I followed forum suggestion to change TTL level to high from low with bad result. At this time I do not know if i have a problem with the PSU I purchased from you. I may have to get replacement to test.
<UPDATE> Replaced original K40 mirrors with Si plated mirrors. Beam and cut quality is very good. I have not made any other changes to focus lens or air assist nozzle upgrade. PSU issue due to known problem with 40W PSU. I am still upgrading the K40 at this time.
