Hi Marco
I just tried to update the firmware on the 608 (V7) with the 130922V7.
Updating stayed on for several minuts, so I reset the controller (should only take like 30 sec).
I tried to upgrade again, but it failed again. (Sometimes it takes 3-4 trieds to get it to upgrade).
Now, when I turn it on, all it does is say "Waiting..", right from the beginning. Ive tried to push all buttons. It beeps when I press Reset, but nothing happens.
Is it bricked or is there something I can do?
DSP bricked - Tried to upgrade firmware
Re: DSP bricked - Tried to upgrade firmware
Just run the OS again. If it won't take it, then run a version older and try the latest one
Make sure you format the USB memory drive in "FAT32". Do NOT format it in "FAT" as the DSP won't recognize FAT
