Where is LaserCut...Corel...
wrench
Post by wrench »
I have the 100mm x 100mm Box drawn in LaserCad. I have checked all of the files that were e-mailed to me from Marco and can not find the LaserCut anywhere.
Also the manual states that there are 3 versions of LaserCad:General (LaserCad), Corel Based and AutoCad. Again, I can't see where the Corel or AutoCads are located.
I have Corel Graphics Suite 12. Will this work (if I ever find the correct LaserCad Version).
To sum this up, Where is LaserCut? Where is the Corel Version (and will Corel Graphics suite 12 work with it).
I am using LaserCad v6.88
Can ANYONE help me here?
Stephen6309
Re: Where is LaserCut...Corel...
Post by Stephen6309 »
LaserCAD is the program used to send the files to the DSP.
If you have Corel or Autocad installed, run the LaserCAD install program again and select to install the macros. This info is in the pdf manual.
wrench
Post by wrench »
OK I will install CorelDraw on the Lasers Computer and try this.
BUT where is LASERCUT?
wrench
Post by wrench »
This is just not working. I have spent hours/days on this now.
I cleared all previous Lasercad,64bitUSB...from my Computer. Cleared my Thumbdrive and went to my e-mail and loaded the LaserCad v6.88B,DSP OS,64bitUSB onto the drive and then loaded it to my P.C as I did before.
Extracted all of it to 7-Zip (.rar extractor) so now it's all on the P.C
CorelDraw is now already set up on the same P.C
This time I open the CoreldrawLaserCut but this time it will not open or even have an icon like it did when I setup the LaserCad (without the CorelDraw). I have deleted everything from the Computer and tried every way possible to open it but I can not get the CoreldrawLasercad to open or work. I had everything running before with the way I opened LaserCad but not with this.
Words cannot explain how frustrated I am getting. I have read almost every post on this Forum. I down loaded and print out every diagram I could find. I can't get this working.
Do I need a new download of Lasercad? a different version?
Post by waltfl »
hi there
did you run macro in CorelDraw tools then select from the down slide the lasercad gms.
to do this you need to open a new file in corel then select tools go down to macro then run macro
click in the opening menue click on arrow halfway down ther select global macro (AWCCorelX5.gms)
select" awclasercutAWClaserstart" and click run. then close the file and open a new one and the icon
should be right there now you can move it to the toolbar.
wrench wrote:This is just not working. I have spent hours/days on this now.
