Bitmaps engraving at a slant
hardshoe
Post by hardshoe »
Hello Marco , pleased to say the machine is up and running . I've been doing some test pieces and I've noticed that pictures that have been cropped and should have a perfectly straight edge are sloped( runs off right to left about 4 mm over 25mm) this also happens to letters that are engraved as opposed to letters that are cut which are perfectly square. Seems to be anything that is a bitmap is behaving like this . Anyone got ant ideas ?
Thanks for your help
Ger
hardshoe
Re: Bitmaps engraving at a slant
Post by hardshoe »
Hello Marco problem solved , I had the x max acc. set to 10k and y set to 6k . Made both 10k and that's it sorted. Blast off for sure now.
Ger
Ger:
Glad that your problem solved. I'd the way you're doing and never giving up. You have been trying very hard to learn 'how to' and finally you got paid back!
Sorry in this case I didn't help you too much. I'm busying doing moving. Once we finished the moving, I will get more room and time to do testing for you guys
