18 to 20 mm focus lens mount misaligned
schuch
Post by schuch »
I just received a focus lens mount. The mirror holder is misaligned to the x axis by about 10 degrees. It looks as if the joint between the mirror holder part and the lens holder part is superglued together on the mounting plate. Any ideas how I can undo this without damaging it?
Schuch
Re: 18 to 20 mm focus lens mount misaligned
Can you post images. Note that the laser tip is moveable and can be tight up by a screw. There is a screw hole threaded, isn' it?
schuch
Post by schuch »
Thanks Marco. I manager to undo the screw with a bit of force.
