I can not connect to the DSP or recognize UDISK.
Posted: Sun Mar 10, 2013 6:53 am
Hi Marco, I have a DSP awc608 purchased in April of 2012, I've put the firmware 121226v7.ug5 and seem to have caught, because when finished will reset.
but the problem I have at the moment is that the software does not recognize LASERCAD 2013 ver. 6.46, which you sent me, both with window XP, as with window 7 32-bit started, well not recognize a FAT32 formatted USB flash drive, and placed into different USB ports. I've also connected NETWORK port, with negative results.
I do not understand because the firmware displays files that I have introduced, but any other file download LASERcad not displayed and no more options left me to do, I've even done formatting the memory of the DSP. I would appreciate if you can help me with something. Also ask if there are any other software to control the DSP that I can use and is as good as the LASERCAD. many Thanks
Jultron.
Jultron.
