Hi Marco, I have a DSP awc608 purchased in April of 2012, I've put the firmware 121226v7.ug5 and seem to have caught, because when finished will reset.
but the problem I have at the moment is that the software does not recognize LASERCAD 2013 ver. 6.46, which you sent me, both with window XP, as with window 7 32-bit started, well not recognize a FAT32 formatted USB flash drive, and placed into different USB ports. I've also connected NETWORK port, with negative results.
I do not understand because the firmware displays files that I have introduced, but any other file download LASERcad not displayed and no more options left me to do, I've even done formatting the memory of the DSP. I would appreciate if you can help me with something. Also ask if there are any other software to control the DSP that I can use and is as good as the LASERCAD. many Thanks
Jultron.
I can not connect to the DSP or recognize UDISK.
jultron
Re: I can not connect to the DSP or recognize UDISK.
You need to set a correct USB port before the LaserCad can communicate with the board.
jultron
Hi Marco, thank you very much for the info, you were right, there was no USB port configured, now works very well. I am very happy with the DSP.
Users browsing this forum: No registered users and 44 guests
