CorelDraw X6
1n2
CorelDraw X6
Post by 1n2 »
Hi Marco
Will the DSP/Lasercad be made compatible with X6? as I am having to save out files "as x4" to convert them and its not always fully compatible.
John
Re: CorelDraw X6
Currently the LaserCad support up to X5 (with Macro). I believe you can use X6 to save as X5 format, can't you?
It's just matter of macro issue and shouldn't have a great impact for the work itself. I'll follow up with this issue with the programmer "Li" and will give him a little pressure to make it compatible to X6
1n2
Re: CorelDraw X6
Post by 1n2 »
Tech_Marco wrote:Currently the LaserCad support up to X5 (with Macro). I believe you can use X6 to save as X5 format, can't you?
Hi Marco
Yes you can save as almost any previous version but you cannot guarantee the resulting files especially if there is text!
I will go back to X4 (as I have it) X6 isn't that much better......
Any chance of Turbocad being supported I have that program too !....(I cannot get on with Autocad)
John
