cutting and engraving
Jacala
Post by Jacala »
Hello!
I've got a problem.
I want to engrave and after that cut out the engraving.
For some reason when I open the JPEG the is no problem but when i try to insert the DFX for cutting it erases the JPEG, the same happens when i do it the opposite way around.
Whats wrong?
Jacala
Jacala
Re: cutting and engraving
Post by Jacala »
Solved!
When importing a file you mus select "reserve the current docum"
Now it works.
