New 4 axis stepper controller (TB6560-4V5 Blue Board)
GiriPod
Post by GiriPod »
Can I get updated documentation for the TB6560 4 axis controller as I can't work out the connections on the parallel port side?
The relay connection is obvious, but there is a 6 way screw down block and a 15 DB connector which I assume are the 5th axis and limit switches.
Re: New 4 axis stepper controller (TB6560-4V5 Blue Board)
You may used the manual for the red board that I posted on the manual section. It's 99% compatible with the blue board, except that the relay pin was swapped between #14 and #17.
Let me know if you still have a problem to configure it.
Return to “Electronics”
