engraving on the same place
Jacala
Post by Jacala »
hello!
My DSP always cuts on the same place, it doesn't matter where i put my image in lasercad, it wil always cut upper left of my workarea.
It must be very easy but i'm overlooking it for some reason.
Who can help me?
Re: engraving on the same place
Post by waltfl »
hi jacala
look at the display menue there is a position ( you have to scroll down) where it says laser software or manual
set it to software.
another place is in settings in the software where you need to select the page size and left up or down, right or left.
Jacala wrote:hello!
Who can help me?
Things
Post by Things »
Look in the DSP menu for "Origin mode"
Key mode means it'll always start from where you set the origin on the DSP with the Origin key.
Soft mode means it'll start where you have it in software.
Machine means it'll always start at machine origin.
Jacala
Post by Jacala »
found it an should have put some more effort into it!
Thanks!
