Hello!
I'm in the stage of cutting my first square to ajust the size.
It wat quite dificult to find out but i'm getting there!
When I fire the laser on the dsp it fires. But when I want to cut the square it makes the shape but the laser does nothing.
I't must be simple but I cant find it. What must I change in the settings?
laser does not fire
Re: laser does not fire
Jacala wrote:Hello!
Check two things:
1. The power setting, for both cut and corner need to be > zero and enough to actually fire the laser (> 10% or so).
2. You have to tell the laser whether to use the settings from the software or from the control panel. This is done in a menu item on the control panel.
the connections where damaged during transport. Bad packaging.
new solder and its fine now
Thanks!
Thanks!
