safety window
Jacala
safety window
Post by Jacala »
Hello!
I'm building a 1000X700 mm co2 laser system based on the DSP.
I can find everything I need except one of the most important things: a safety window.
I would like something like 30X30" so I can see ass much as possible. But where do you guys buy a window or what do you do about safety? Work with a open system and wear goggles?
I'm curious what you guys do.
twehr
Re: safety window
Post by twehr »
Jacala wrote:Hello!
All you need is simple plexiglass. It stops all 1060nm rays.
Jacala
Re: safety window
Post by Jacala »
mmm Are you sure?
What will happen to the plexiglass when I put the laser on it?
geotek
Re: safety window
Post by geotek »
It absorbes the 1060nm IR like a sponge. If you have enough concentrated energy, it will melt. Have you ever cut acrylic on a laser?
Things
Re: safety window
Post by Things »
^ 10600nm
As the laser should never hit the window at full power, only diffuse reflections, it will have negligible impact on your window.
Jacala
Re: safety window
Post by Jacala »
yes I did cut plexiglass, nice effect for namesigns etc.
but yeh, a unfocused beam would have trouble burning trough a plexiglass sheet of lets say 1 cm thick.
I'm gonna try it to be sure how long it takes.
Thanks!
Jacala
Jacala
Re: safety window
Post by Jacala »
What thickness do you use? I can get a 5 mm sheet quite cheap but i'm concerned that it is not thick enough.
What size is "normal" in the co2 business?
