Start point in Lasercad v5.95
Posted: Sun Jul 08, 2012 7:21 am
Hi All,
I have been having a lot of fun with the 2012 DSP and have learned a lot. I've been happily test cutting a number of materials. I came from the CNC router world and use Vectric's Aspire product. I am quite familiar with node editing and and start points for cuts. In Vectric Aspire, when I go into "node edit" mode and I select a vector object, I can manually change the start node. I've been searching for this functionality in Lasercad, but have not had any success.
Two questions.
1) Is there a way to manually change the start point for a cut directly from Lasercad? For example, if I left click on a node in Vectric Aspire, one of the choices is "Start Point". When I go to cut something on my router, it will start the cut from the point I designate or an automatic point if I don't specify. Usually, these points are corners and not sides (unless the vector is an arc) to make the entry and exit points less noticable. I know that I have the option in Lasercad to add ramp in and out (called "auto cutting guide line" in Lasercad) but usually these points are the sides of even square objects. I can't change where these points are put in.
2) If changing the start point is not possible directly from Lasercad, can I do something in Corel X5 to let Lasercad know where I want the entry point to be?
Thank You,
David
Two questions.
Thank You,
David
