Hi,
I am new to the lasercad software and I am wondering if anyone can tell me what good settings are for engraving rubber stamps?
I have currently tried .bmp and .jpb image files - both with set to engrave at 20mm/s and 98% power.
the engraving works but I would like to make ramps or supporting edges around the remaining stamp parts.
I have tried the "grade engrave" setting at
grade Length(mm):0.75
MinPower1(%):75
but with or without the "grade engrave" the results were the same.
Is there a stamp "mode" ?
I suppose I could redo the art in vectors and attempt to design vectors to be cut or engraved at a lower setting but that seems like a lot of effort!
Thanks for any advice.
Rubber Stamp Engraving Settings
Re: Rubber Stamp Engraving Settings
I still have no idea what the grade engrave does, but I was able to produce some fairly nice stamps.
Here are how they stamp
and
and
Having re-read some older posts from Marco, I tried today to make a 'return address' stamp .
Being all text, I thought it a good opportunity to try "grade engrave" again
Unfortunately even with the job being nothing but text, grade engrave setting has absolutely no noticeable effect.
I tried both creating the job in coreldraw then exporting to lasercad and also creating the job entirely within lasercad.
Neither technique produced a very good return address stamp. The letters are too narrow and they bend over when stamped producing a blurry line rather than a crisp one.
- ReturnAddress.pwj5
- (131.24 KiB) Downloaded 139 times
That's frustrating...I hope the 'grade' portion gets fixed eventually. I'd love to be able to make stamps...
yes. me too. The ability to make rubber stamps was a key point in convincing my wife that this was a "good idea"
However, as in my above posts, it is still possible to make a relatively successful stamp as long as you consider the widths of the lines and plan for adding enough thickness to support them.
I will try to take some time to figure out if there is a way to easily use coreldraw to create ramps but I would ask Marko to please encourage his programmer to make this a priority because it would definitely help sell the DSP board. I know for sure all of the major suppliers of laser cutters provide a rubber stamp mode.
Users browsing this forum: No registered users and 58 guests
