Can someone please explain the pinout pattern of the thermocouple (thermistor in this case) inlet of the JLD612? The PT-100 has three spade terminals, two blue and one red. The JLD612 shows pins 8,9 and 10 involved. From the label I infer that 9 and 10 get a blue (showing + & -, and resistors are not sensitive to polarity) and the red goes to 8, signified by an "R" in the schematic label. Before I hook this up, can someone please confirm my suspicions? If I'm wrong, correction is encouraged!
Dave
PT-100 and JLD612 question
soopirV900
tonylange
Re: PT-100 and JLD612 question
Hi Dave, just had the same. You wont bust the controller. just use the two red ones as the + - and the odd as the common. T
