New 40W/60W Laser engraving cutting machine
Found a great laser machine in China. Nice DSP controller, high speed roller, inter air cooling system, and beter wiring system. It runs 800mm/s for engraving
See detail: http://www.lightobject.com/Product3.asp ... egoryId=37#
http://www.youtube.com/watch?v=2Ary5LNKitQ
Re: New 40W/60W Laser engraving cutting machine
More images
Very neat and well ogranized wiring setup
You will be amazed that they install a air-cooling radiator for the water cooling. Smart!
Temperature for CO2 laser is critical. Watter better not over 30'C for better performance.
It's a Roller type laser module, not slide rack! It means it's faster, smoothier, and less trouble
Nice aluminium made Y axis driver
Nice aluminium made X axis driver
It's a honeycomb working table. It helps for cutting and object not easy to slip away. Plus, it's removable. For bigger object (thickeness), you can take this plate out to accommodiate for the bigger object.
A new CO2 machine that I just ordered! It's top speed can reach 1200mm/s (straight line). A very solid custom built machine that support 60W laser (see the extra cage).
