Where to find DSP Software ?
Re: Where to find DSP Software ?
spektrum wrote:So is it possible to alter the 'laserstart' macro to automatically start the laser cutting process? Alternatively can you create a shortcut key for the 'start' button in LaserCAD?
No you can't. You need to use LaserCad to set the speed and power before it start to process your job file
o999
Post by o999 »
Where can I find the DSP software to suite my board ( order #85753B)?
Thanks.
Cheers,
David.
o999 wrote:Hi,
Can I get a link?
Order #85753B (March 2011)
David.
David, are you running LaserCad or PHCad?
I don't have any update for PHCad
Send me a picture of the mainboard if you can
o999
Post by o999 »
Tech_Marco wrote:David, are you running LaserCad or PHCad?
A picture of the main board is attached.
I'm not running any software with the board at the moment as it hasn't been installed. I bought the board to upgrade a laser printer running the "infamous" MoshiDraw, but for various reasons I was delayed in completing the project.
Basically I am just hoping to end up with something usable, so whatever software is available I'll try.
Thanks.
Cheers,
David.
David:
That's an older DSP board (I named it 2011 DSP) that 'we' stop making or selling after 2011. The programmer formed a new company and came up a new DSP card "AWC608" on 2012 and that is the card that I'm carrying. That's a long story about that card 2011 (not a please one :( .
Anyway, you need "PHCad" instead. See the link here: viewtopic.php?f=55&t=660
o999
Post by o999 »
Tech_Marco wrote:David:
I have seen that link before - but where can I get the PHCad software?
Cheers,
David.
o999
Post by o999 »
I just searched and found a copy of PHCad_v4.38 that I downloaded in March 2011.
Is that the only software I will need to drive the controller?
Thanks.
Cheers,
David.
docwiz
Post by docwiz »
I also need the firmware and lasercad please
My order number is 200818
My email docwiz3@bigpond.com
neosamuri
Post by neosamuri »
Can I get the software as well please Order # 200763
Post by Techgraphix »
Ordernr 201031
Please send me the link too..
JacobKritzinger
Post by JacobKritzinger »
Hello Marco,
Please also send me the Firmware and LaserCad Software.
Order number: 201023
THANKS!
Dovo
Post by Dovo »
Hello Marco,
Please send me the Firmware and LaserCad Software.
Order number: 198989
regards
Andrea
1n2
Post by 1n2 »
Hi Marco
What is the latest Lasercad version?? (and AWC608)
I am still having real problems trying to sort my machine..... (awful engraving).... so I decided to completely reinstall everything so I can "fault find" with no legacy on the machine or PC.
John
John. There is no new update software available. The software has nothing to do with the engraving or cutting. You need to check your parameter setup and/or mechanic & wire connection.
1n2
Post by 1n2 »
Tech_Marco wrote:John. There is no new update software available. The software has nothing to do with the engraving or cutting. You need to check your parameter setup and/or mechanic & wire connection.
Hi Marco.
Ah well i was hoping there'd be a version to woark directly with corel draw 6.
As for my other issues i will open a new thread
John
