CoralDRAW X6 issue
Rad Racer
CoralDRAW X6 issue
Post by Rad Racer »
I upgrade my laser computer to Windows 7 (64 bit) and now have an issue with LaserCAD 6.81 finding the CoralDRAW program. When I select "CoralDraw_Lasercut" from the setup menu it comes back with the error that it "Can't find CorelDraw".
Has anyone experienced this issue?
Software installation details:
Windows 7 64bit
CoralDRAW is installed as 64bit
LaserCad 6.81
Hermes
Re: CoralDRAW X6 issue
Post by Hermes »
Your coreldraw installation path probably isn't the usual one or the registry entries are either missing or incorrect, try re-installing corel.
Hermes Sandoval.
Rad Racer
Post by Rad Racer »
Problem solved....
Install CoralDraw X6 as 32bit and the Lasercad installation works fine.
