Engrave Beyond Size error
rushmore1305
Post by rushmore1305 »
hello
i am trying to engrave anything but text, no matter what kind of resolution im using the controller always comes back with an error
can someone plz help me, what am i doing wrong here
Re: Engrave Beyond Size error
Post by waltfl »
hi rushmore
reduce the speed or move the object away from the border
rushmore1305 wrote:hello
rushmore1305
Just tried adjusting it and still the same issue!
I think you are right about the close to border
For some reason even when I do a cut if I move the item to say middle of the workspace the controller still starts it at very top right
How do I fix that
I don't get what I'm doing wrong here
Also will post my engrave settings just so u guys can see maybe something is wrong there
Or is there a setting that tells it to start at the top no matter what that I don't know about
waltfl wrote:hi rushmore
Post by waltfl »
hi rushmore
you need to set the settings on the LCD display to soft and in the option check the right settings
rushmore1305 wrote:Just tried adjusting it and still the same issue!
How do I fix that
rushmore1305
ok i was pretty sure i did that
look at these settings plz.
also anyone have link to new lasercad cause im on 6.71
Post by waltfl »
hi rushmore
first the laser 2 should always be zero if you don't have two lasertubes.
but you need to check the setting in the manufacturer settings and then on the machione LCD in menue that you have set to soft
rushmore1305 wrote:ok i was pretty sure i did that
rushmore1305
So great news. I had upgraded my laser cad software to the latest version and the OS on the controller.
All of the issues seemed to have gone away.
I'm able to engrave and everything.
Verry exciting
Greolt
Post by Greolt »
If you have "Work Space" set wrong, that will also result in the error you are seeing.
These are my settings. Yours may not necessarily be the same.
Telrad
Post by Telrad »
I get that error sometimes when I use the AI method of import. I switched to DXF and the error went away.
