Wiring the awc-608 control to the 2m656 stepper motor driver
jarbon
Post by jarbon »
Hey guys. I'm new to this, and I could use some help.
I received this wiring diagram from lightobject: download/DSP/LaserMachineWiringDiagram2.jpg
But, its wiring is for the m415b driver, and the terminal text does not match the terminal text on the 2m656 drivers.
I was trying to "wire by the numbers" but this has thrown me and I don't want to blow anything.
Does anyone have a schematic for wiring the awc-608 controller to the 2m656?
John
Re: Wiring the awc-608 control to the 2m656 stepper motor dr
See AWC608 interface file I sent you. I clearly show you how to connect the stepping motor drive in general
DIR+ and PUL+ tap together and connect to DSP +5V
DIR- to DSP DIR-
PUL- to DSP PUL-
Then power the stepping motor from DC24V to 36V. That's all you need to do
jarbon
Post by jarbon »
Thank you, Marco. I don't have that file, as I purchased the kit, steppers, control board, and other components from my neighbor (who got them from you) because he didn't have the time to complete the project. :)
Can you tell me where I might download that file?
John
jarbon
Post by jarbon »
One other thing.
Would I be correct in assuming that on the 2m656 the "PLS" = "PUL" you mentioned in your post above?
I don't need the "ENA" terminals?
John
jarbon
Post by jarbon »
I found the interface file. Thank you. That is more clear.
John
Return to “Electronics”
