I got my new PSU in. Looks fantastic and runs good when I hit the test button.
But I can't get it to respond to my TTL logic. It has the TTL light on...it doesn't want to turn off, even if I disconnect the whole wire harness. It won't respond to High or Low fire signals. It's driving me crazy.
Any tips? I can't find any PDF's relating to it and I'd really like to get my cutter running again...
Laser PSU Question
Re: Laser PSU Question
Look like you haven't enabled the PS with "WP" connect to the ground. It is a water flow protection. It usually connect to a water flow sensor with normally opened contact. If you don't use water flow sensor, just connected it to the Gnd and it will enable the PS.
See manual: download/file.php?id=32
Axeman
Ah, I see!
Thank you, much better now. Not used to this higher quality equipment
