Z axis soft limits
Telrad
Re: Z axis soft limits
Post by Telrad »
I just came back on Monday night. What a trip, fast and rich! :lol:
I talked to "Li" and he said that it was "Impossible" the new OS could affect the Ethernet connection. He suggest you to go through setting again and make sure the IP setup was properly configured.
Telrad
Post by Telrad »
I re-flashed the laser and so far so good ethernet is working!
Gadroc
Post by Gadroc »
What's the status of this firmware version? It would be really nice not to have to zero my Z table every time I power up!
There is no other update on the OS for the Z. I think it is so far so good to meet most need. You can diable the "Z axis home on Power" by unchecked it and the Z table won't go to Home everythime you power up the machine.
Gadroc
Post by Gadroc »
Ok.. How do I get a hold of the version of firmware that has Z soft limits disabled. If I disable home z on startup I end up with problem on the soft limits.
