Hello,
I just got in a G-Weike 80watt LC6090 laser. It has the MPC65150 controller board and required LaserCut5.3 software. I've never seen such terrible software. Total garbage even when I can get it to work.
I read a post at a different forum recommending the LightObject board.
Is there anything else I would need other than the LSR-4XDSPV2012?
It looks like it's almost plug and play with the same connectors and everything. Seems too good to be true. I can handle just about any complicated installation but I'd like to know what I'm getting into first.
The video on the product description is not available. Does anyone have a working link?
Here is a closeup of the MPC6515C
Entire controller area
MPC6515C to DSP conversion questions
refurbsupplies
Re: MPC6515C to DSP conversion questions
If you can read the connection on the MC6515, then it's easy for you to do the AWC608
See attached image (conneciton diagram of AWC608) created by one of our member.
