JLD634 120v rellay output?
autocharge
Post by autocharge »
Specification
Dual output SSR(6V, 40mA),
Relay(3A 120V AC)
I'm confused on how to wire and enable the rellay (3a 120v AC) option.
The manual didn't help me any, 3~100 second number value???
should it be done with J1 or J2 output's ??
any help would be nice.
Thank you
richiem
Re: JLD634 120v rellay output?
Post by richiem »
I looked at the manual, and with just a brief perusal, I couldn't figure it out either. I just don't know what the time interval does. It's obvious that the unit can be programmed to use the relays, but anything after that is a mystery. Sorry.
autocharge
richiem wrote:I looked at the manual, and with just a brief perusal, I couldn't figure it out either. I just don't know what the time interval does. It's obvious that the unit can be programmed to use the relays, but anything after that is a mystery. Sorry.
What I did was to use the SSR to switch on/off a double pole mercury relay for my 220V kiln. Work just as well. Thanks for the reply.
