Help for connecting DSP with TB6560
Lumifab
Re: Help for connecting DSP with TB6560
Things
Damn, now I'm wishing I had bought some stepper motor drivers! Need to get my machine running so I can start making money to upgrade it!
Lumifab
I was able to activate and control both the X and Y steppers of my machine.
But it's not over... I am currently fiddling with the limit switches wich are optical. They are located at the max X, and Y=0, so I am trying to figure out how to config Lasercad and the DSP... Any help available on Lasercad options ?? Datum and Key direction seem to be related to my problem... And on the DSP, should I connect to a wire on the ELX+ terminal since my X swithch is at maximum (900mm). ?
thanks
