Help with the DSP AWE-608 2012
Re: Help with the DSP AWE-608 2012
Post by waltfl »
Hi
just look here this coiled hose is perfect but needs to be shorten.
http://www.ebay.com/itm/270789661748?ss ... 1438.l2649
Gadroc wrote:I have a temporary air assist hack setup, but am looking for the same thing. Bdring is out of stock on the nozzles over at buildlog, he said a few weeks. I have not found a nice precoiled hose either as I would rather avoid buying a cable chain until I want to upgrade to laser 2.x. Currently I just use an airbrush nozzle and hang it off the focus mirror mount with wire and just run surgical tubing. Took some fidlong to get it setup to not fold down under the laser. I'll take pictures when I get back from visiting family.
I do have the air assistant laser head, the connector, and the tube. It's desgined for the K40. However, there is a few screw missing on the aiir assistant laser head and I need to find it from handy shop.I'll post some pictures here later
wctx1977
Post by wctx1977 »
I would like to see those pictures about the air nozzle kit you have and how much would that cost all together, just let me know whenever you get around it. Thanks
Edgar.
Gadroc
Post by Gadroc »
Same here. I would like to see it with cost as well.
Craig
Post by baccus61 »
Some auto store have air tools that use the small coiled air tubing. You might want to try them and see what they have. You can also search eBay for them.
Here is a link from Australian eBay for something like you are after.
http://www.ebay.com.au/itm/1-4-x-25-foo ... 53ea4a30c4
Picture shows what I'm carrying.
Also, air tube: http://www.lightobject.com/Tubing-C57.aspx
Very competitive price :mrgreen:
Post by waltfl »
Hi marco,
I could not find a coiled hose and the airassist nozle wher is it the link just gives tubing.
gretings
Tech_Marco wrote:Picture shows what I'm carrying.
Gadroc
Post by Gadroc »
When are you going to be selling that nozzle? I'd love that instead of having to screw an nozzle on top of the lens holder.
Gadroc
Post by Gadroc »
baccus61 wrote:Some auto store have air tools that use the small coiled air tubing. You might want to try them and see what they have. You can also search eBay for them.
Those 1/4" hoses are far to big and stiff to use, they would add too much drag to the laser head assembly. I have one in the garage on my compressor. Actually I think the surgical tubing I'm using is to big. I'd much rather have a coiled 1/16th ID hose, but I've had no luck finding one.
I did order the hose that Walt link which should be here in a week or so. I'll let you know how that goes, otherwise I might just have to bit the bullet and but on a cable chain.
wctx1977
Post by wctx1977 »
I can't find that air nozzle in your site. You posted a link for the tubing, can we have the one for the air nozzle kit as well so we can see the price?
Edgar
You don't need to use the coil tube but staight type tubing instead. Coil tube looks short but it's long and the weight of it may cause some 'over-loading' on the K40 . Remmeber that K40 only comes with two small 42series motor.
I haven't posted the air assist laser head yet as I need to find two tiny screws that supposed to come with. It's used to lockup the bottom part of the laser head. Without it, the cone part will fall off. Been talking to the supplier but they have louzy customer services and ignore my request. So, I'll find another supplier to make it in the future.
By the way, I have better ZnSe focus lens for the K40. If you found that the cutting power is dropping, you may try mine. The ZnSe that comes with the K40 is very low grade type. I'll shoot some picture for the comparsion.
Post by waltfl »
hi marco,
my k40 came with 2 nema 17 motors and the coil is not the automotiv version it is the 1/8 version for airbrush work.
where can I find your new ZNSE lenses??
OH by the way did you get my package with the DSP board?? its now 3 weeks.
Tech_Marco wrote:You don't need to use the coil tube but staight type tubing instead. Coil tube looks short but it's long and the weight of it may cause some 'over-loading' on the K40 . Remmeber that K40 only comes with two small 42series motor.
