Okay - maybe I was a bit ambitious for a first build but I'm sure I can do it.... I think.
It would certainly help if there wasn't so much conflicting information though!
Here's my latest dilemma. MY Y motor only has 3 wires as stated below but when pulling up the product page it lists it as having 6 wires....
Additionally, as you can see below, the X motor claims to have 3 wires but mine has 6...? This matches the product page.
So, setting the driver to 5.8 A for a test, I get a very shaky start until the DSP boots. According to the diagram I was sent, there is a jump between PUL+ and DIR+ ... anyone know if this is correct?
Specification:
X motor:
Brand: Lightobject 573S09 3-phase
Step angle: 1.2 degree
Torque: 128 oz-in
Current: 3.5 A
Resistance: 1.3 ohm
Inductance: 1.7 mH
Detent torque: 4 N.cm
No. Wire: 3
Weight: 0.75Kg (1.65 lb)
Y motor:
Brand: Lightobject 573S15 3-phase
Torque: 188oz-in
Current: 5.8A
Resistance: 0.7ohm
Inductance: 1.35mH
Detente torque: 6.8 N.cm
No. Wire: 3
Weight: 1.1Kg (2.4lb)
NEMA 23 3 PHASE 573S15 5.2A 212IN-OZ STEPPER MOTOR
Re: NEMA 23 3 PHASE 573S15 5.2A 212IN-OZ STEPPER MOTOR
Based on my response fro LO Support, I need to set the current to one step lower. That's fine.
Still, any thoughts on my motor acting crazy during boot? Humming, spinning, and sputtering.
Just received some AWESOME support from Marco.
Turns out I have a bad driver and he's replacing it...
I knew I wasn't nuts!
Thanks Marco!!!!
Thanks Marco!!!!
