Hi,
I am new to this forum. I have built several CNC machines but this is my first try at a laser. I have an older LMI lasergraver 2 which I plan to update. It has a 30 watt Synrad laser (rf?) instead of a glass tube laser.
Can the DSP be used to control this laser? Also what does DSP stand for?
Bill
New member basic question.
Re: New member basic question.
bgriggs wrote:Hi,
Bill
Easy question first - DSP stands for Digital Signal Processing. A generic term but in laser control, it is the top of the line method.
For the Synrad compatibility - I believe it should. I know there have been conversations on the board here about use with possibly Synrad and/or other rf lasers. I think that the laser signal frequency is more critical for RF, but that is configurable in the DSP. As I recall, the DSP setup includes setting for either RF or Glass (at least the earlier version did), so my guess is that it should work.
Thanks for the response. I have been looking forward to tackling a laser upgrade. Now with the amount of info here, I think I can do it.
Bill
Bill
